TwinTurbo.NET: Nissan 300ZX forum - Make sure everything is on tight and straight.
JonnyZ(SoCal)
on August 03, 2012 at 12:30 AM
TB slipping.
posted by gbeto
on August 02, 2012 at 08:17 PM
When you rotate it, observe each gear/pulley and make sure they don't wobble. Did you remove the cam gears at any point?
TB slipping.
gbeto
20:17:29 08/02/12
It's the crank sprocket guide washers (probably) -
jzack
20:49:28 08/02/12
Re: It's the crank sprocket guide washers (probably) -
gbeto
20:55:51 08/02/12
no difference between the front and rear crank tb guides (n/m)
thumper (Los Angeles)
22:29:41 08/02/12
Re: no difference between the front and rear crank tb guides
gbeto
23:02:44 08/02/12
that's limited by the crank, so I don't understand your ? (n/m)
00:06:24 08/03/12
It's pretty tight, very little slop..... (n/m)
jzack
01:56:23 08/04/12
There is a Difference in front and rear crank spacers/guides
toykoz32
02:14:28 08/03/12
Sorry, you're correct
11:23:07 08/03/12
Re: Sorry, you're correct
elcid
18:06:58 08/03/12
Make sure everything is on tight and straight. -
JonnyZ(SoCal)
00:30:40 08/03/12
2nd^^^^ (n/m)
toykoz32
02:16:25 08/03/12
Looking at your photo the right intake gear may not be in
njz
06:02:41 08/03/12
And the reason was.
gbeto
20:23:48 08/03/12
NVM my post
90GoldZ
20:57:08 08/04/12
Just delete your post then. (n/m)
Woody75 (Denver)
23:30:24 08/04/12
Re: And the reason was.
wild_maxx
17:34:05 08/05/12
Hmmmm..
90GoldZ
20:55:16 08/04/12
